plol hahaha
so i just finished creating a dream list of parts..
all mainly Mines..
and then i saw.. the price of them rebuilding your engine..
about 23k + freight..
Edited by Redsuns88
23k for a 26?? Sure the mines car is responsive, but i know a better way to get response for that sort of money.....OS Giken RB30 :whistling:
Ive pretty much got my dream list, all i need is an assembled bottom end and decent brakes!
plol hahaha
all mainly Mines..
Depends on what you get for that 23k. If thats for a crate motor all ready to go incl ancillaries(spelling?) then its not too bad.
Giken 30 you pay 23k just for the short block! Whats the specs on yours?
oh and newer suspension, its ok but it looks like its very old
Bilstein Kit from Dan is good :thumbsup:
plol hahaha
all mainly Mines..
Just reread that and saw that word lol. Again it depends on what you get in one of their rebuilds but 23k is f**king exxy.
its got the head too with cams of your choosing it was 26k last time i checked for that, but that was delivered.
General specs are
HKS 2510s that were slightly highflowed upon rebuilding so are rated at about 325hp each instead of 310
Ported Head
Tomei Poncams so whats that 260 somthing degrees and 10mm of lift? somthing like that anyway
Power FC (Want to change that to the new adaptronic super ECU)
Z32 AFMs
Sard 750cc injectors in a Sard fuel rail with a sard FPR and some big intank pump
Trust dumps and front pipes into some random 3.5 inch exhaust
ARC intercooler
Profec B spec 2
Apexi intake piping and pods
NPC Twinplate
Rebuilt Gearbox
Rebuilt 4wd system
Rebuilt drive shafts
19row oil cooler
Oil mods to the head, restrictors drain at the back of the head ect
Baffled sump
Currently being done
Rebuild including:
ACL pistons
Spool rods
and new billett oil pump gears designed by shrek and ranga
external fuel pump and surge tank
I think thats about it
Tis a very nice list :D
omg colin since when do you design stuff? :whistling:
:thumbsup: I don't. Not oil pump gears anyway. That be Shanef :D
i have literally deflated my left nut over this..
and my right one
tomei?
FK this, I wanted to add my even sexier dump pipes but i can only fast reply as the frigging normal buttons dont show up on the f**king computer for some reason! :whistling:
nope work computer, im betting that the image for the button is hosted somwhere that is blocked auotomaticly, lots of threads have no pics on this comp too, but not a notification that its blocked jest a big area of nothing
I feel ya pain, I get heaps of plank spaces on my work pc too :whistling:
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
