funkymonkey
you would have liked Noels old engine bay ha ha very shiny
nine is pretty boring, just looks stock with white covers
I like yours with the white covers. Are they a bitch to keep clean though?
+1 for stealth spec bays. I like the blinged up bays aswell though. As long as the covers arn't chromed. Chrome covers are gayer than aids. :whistling:
on starnge note though
the sticker imprints that are on my car one special one saying "Battle Club"
actually makes the best wheel spacers on the market..
sigh..got my hopes up.. really wanted to see how it was present in japan :whistling:
atleast i know i have wicked spacers on
<ftmperrorloginfo>
<datetime>15 October 09, 16:24:53</datetime>
<appver>2.18.12</appver>
<projno>14194</projno>
<userid>QA</userid>
<errorno>1</errorno>
<actor>_USE</actor>
<dscrptn>File 's:\...\5acbe36c-4d52-443e-ae3d-823032419249rr0tmhkd\config\dfsec.dat' does not exist.</dscrptn>
<usermsg/>
</ftmperrorloginfo>
<ftmperrorloginfo>
<datetime>15 October 09, 16:24:54</datetime>
<userid>QA</userid>
<errorno>13</errorno>
<actor>_CHKACCS</actor>
<dscrptn>Alias is not found.</dscrptn>
<usermsg>Display Message :
Program Sequence:
6._chkaccs.fxp
5.
4.
3.
2._appinit.fxp
1.s:\hilton @ surfers\5 safety quality environment\quality\defects management\qasoft\defectinspector\defectinspector21812.exe</usermsg>
</ftmperrorloginfo>
WTF Does that mean.
i dont like poolished up engine bays..
i rather play the game of hide and seek :dry: with trying to retain the factory look :)
works well with tristans 180
Well you don't want to look at mine because I would never get you out of it...
it means suggadik Colon! :P
lol
Fixed it. All I had to do was tell it to go f**k its own face and then it worked...
FKN LOL ;)
What are these defects you speak about??
the cop pulled him up and defected him for gutter rashing such porn rims. then yelled "needs more low" and drove off into the distance.
tas check ya pm
i just saw a Z4 hard top.. omg jizzz
Defects for the prototype units that we're building atm. Build them off site in a shed then go through and find all the common problems with set out, services etc so its all minimised when it comes to the real thing. Problem is I have to set up the defect software that we use to keep a library of all the defects that get raised. Its a good system but a flamin mongrel to set up.
tas check ya pm
Made me lol. Then I cried a lil...
+1 for stealth spec bays. I like the blinged up bays aswell though. As long as the covers arn't chromed. Chrome covers are gayer than aids. :P
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
