lol no... more like a shift knob and shift boot.
why do you always get poisoned by servos?
He is weaksauce thats why.
Tristan that shit is old but still makes me lol.
Work is gay. Lunchtime. I think I will have some croissants.
The red skyline has similiar to this
http://www.enkei.co.jp/jp/products/wheels/...line/index.html
as for the black rim i think thats the old enkei style as i was telling u last night at my shop
i think what gets me the sandwhiches and that travelers chicken pie..
fffuuuu
fffuuuu
Those black rims are from the '09 Enkei catalogue :P and I think I'm starting to like them more than the 10 spokes... so I'm thinking either 9 spokes, or 3 spokes. Depending on how much I've saved by the time I destroy the 33rims trying to keep up with Colin on Kyagular (sp?) road lol
QFT
I know Colin and Tristan will both fap hardcore over these. I sure did! Anyone else, feel free to as well!
oh balls yeh
waits for martins "yeeh boys i already have them im rad blah blah blah"
yes i have all ranges of sparco shiet in stock..
after a fancy pair of gloves to be like tsuchiiya?
ORLY? I might be keen for some gloves and/or boots. Got a catalogue or price list or anything?
3 spoke advans ftw!
QFT
QFT
+1 :P
Yeah Super Advans are definitely fap worthy
whats teh difference between me and you?
whats the difference between me and you?
Back when Cube - was rollin wit Lorenzo in a Benzo
I was bangin wit a gang of instrumentals
Got the pens and pencils, got down to business; but sometimes
the business end of this shit can turn your friends against you
But you was a real nigga, I could sense it in you
I still remember the window of the car that you went through
That's f**ked up, but I'll never forget the shit we been through
And I'ma do whatever it takes to convince you
Cuz you my nigga Doc, and Eazy I'm still wit you
f**k the beef, nigga I miss you, and that's just bein real wit you
You see the truth is
Everybody wanna know how close me and Snoop is
And who I'm still cool wit
Then I got these fake-ass niggaz I first drew with
Claimin that they non-violent, talkin like they *voice sample*
Spit venom in interviews, speakin on reunions
Move units, then talk shit and we can do this
Until then - I ain't even speakin your name
Just keep my name outta yo' mouth and we can keep it the same
Nigga, it ain't that I'm too big to listen to the rumors
It's just that I'm too damn big to pay attention to 'em
That's the difference
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
