Hell yeah! Just spoke to the EFI boys and they are INNNNNN!.
What do they need to bring.
Awesome. They can bring their Rainman customers along to rip hektik skids on Webster Rd. Hopefully a truck will collect the lot of them. Failing that, the cop shop is just down the road. I imagine it'd be defect central from that workshop anyway. The cops'll have a ball!
updated the group buy, $400ea. :ninja:
John, no r100's sorry breh.
Thanks anyway mate - guess it's gonna be an import job
They want to know what to bring. Tissues...Icecream...Skidz??
hey lads i work at the regatta, i drive a black 32, its parked there most days, maybe some of u may have seen it? anyway just saying hi. i dont really have anyone to go for drives with so i usually go by myself. do u guys go on cruises much? id be keen to tag along some time. cheers adam
EOI at this point.
I need a hand to do a few things around the shop.. and i was wondering if you guys owuld like to pitch in and give a hand.
so i thought about holding a BBQ when the rain clears and shit like that... just a EOI at this present time..
BBQ/drinks. shit talking then need a hand diong stuff :ninja:
Yeah I'll help out if i got nothing else on whenever you organise it. What shit we gotta do?
updated the group buy, $400ea. :)
What about R200 longnose, 3.9:1 ratio?
:P
hey bro i think ive parked next to you a few times in my old grey r32
always welcome to join in on the fun :banana:
Hey man, what do you do at the regatta? I work just behind you guys at the honda joint. Haven't seen your car though, then again, don't usually go into the carpark there.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
