as much as i hate watching that proactive and miricle blade shit...i'll still sit there and watch it, not like there's anything else to watch. What ever happened to all the calling in guessing words games. Just realised they were all gone. Probably for the best.
The word games were on earlier than the infomercials!
They were usually hosted by some loser from big brother or something equally as horrible and displayed just how stupid the population of this country can be. So I'm glad they're gone!
and every day is a good day for a day off :banana:
Yeah that's right. I remember why i hated them now. But yes, i just wanted a taste of your good life john. Tried to sleep in but body clock wont let me.
Maybe its time we organize for a dinner at southside!
On a side note, isnt this the 33gtr driven by a chinese guy that rocked up the at the car wash?
http://www.skylinesaustralia.com/forums/95...le-t293695.html
Just checked it and it is! That was a quick disposal.
Wheres those photos Michael? Check the plates!
sth side dinner sounds good. with or without cars? (piss up?)
just checked the pics and yes, that is the one we saw few weeks ago at the wash. what was wrong with it tas? or was it the black one...i forget.
Yea sounds good. Little Singapore??? Hahaha. Or maybe just go to Tas' favourite place, the old "Shiok". I'm sure John (southside John) would be up for it.
Both have something wrong with them... Hahaha. Black one's got some weird sound from gearbox, clutch or something. Silver turbo sounds like its dying. I remembered he mentioned got that gtr for 17k...
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
