silver one sounded rough as guts. Wouldn't touch it with a 10 ft pole. Although if you got it for 15k and put some money into it you would have a pretty cheap 33 gtr.
Bah Saturday night was shit. Lost $250 to bad luck carnts! puts back the 31s progress a couple of weeks at least. Liverpool won on the weekend though so :banana::D:D
Oh and all my uni assignments are doneskies! Now just got to learn everything for my final exams hurrah.
If you can get it down below 15k, it might be worth it for someone thats gonna do up a full track car. After selling the bits in the car that you dont need, it will definitely be worthwhile. But at 19k... I dont think anyone that knows a bit or 2 would touch it, not even me when I dont know shit 1yr ago. Hahaha. At least I know if those 2 turbo goes, you'll be looking at 3-4k to replace them with labour included.
It's parts vaule would have to be 15k.
Which brings me to my next question; lol at people offering less than what a car is worth in parts.
People like me will only part out cars, thus bringing the over supply down and price stable.
Only works that way if people want to waste 6 months trying to part out a car. The majority of the parts value would be in the engine anyway and its definitely on its last legs. For every 1 person thats willing to sell there car as parts there are 10 more willing to sell it for less as a package.
Only those who borrowed to high hell.
I've noticed, with Gtst's at least there has been a turn, if they cant sell them they will just keep them. Which is fair enough.
Either way you wont make any money out of parting a car. Its only a matter of time before they're all as cheap as 31s lol.
You might be suprised.
Lights, trim, little tid-bits etc. All bring good money as the cars get older.
Noel is a prime example of making very good money out of parting out perfectly good cars.
the last car Noel parted out he managed to get for 4k and didnt make a massive profit or anything...and he still has bits of it sitting around!
But yeah the price he got it for was hardly typical!
Yeh and with that car, what if he tried to sell the shit on all the sites.
sd
pf
boost
ns
ect
Put half an effort in.
My point is, you're all a bunch of tight kents and want everything for nothing. Nothing shits me more then some smart ass trying to offer less than what the car is worth for parts.
I enjoy nothing more then closing the garage door in people's face's saying I have no desire to sell my shit to you anymore.
I didn't think he made that much out of it?
sd
pf
boost
ns
ect
Depends on how much you value your time I spose. I wouldn't be arsed parting out a car for an extra 2k when I can just sell it for less and be done with it.
Because I think $5k R33's and R32's are too cheap and if someone wants what I have I will sell it for what I think it's worth. Every single car I have owned except the Lexus and quick R32 I got more then what they are worth... I dont plan on changing that
If that means stripping the kent right down, I will.
I'm a bit of a shit of a person to buy from, not wasting my time comming to my house to get a closed door in the face :(
can i like be at your house one time when you do that - i rkn itd be freaking hilarious
Sure. I have nothing for sale atm though. Other than parts, which arent of vaule to me tbh.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
