That was a really good edition of mens health, they had an article you would have been interested in called "how to loose 20kg in 20weeks"
Was that your little secret u was trying to tell me??
about how u pop pills and dance like a fag in heat at the gay clubs?
sorry matey.. you have to understand i dont like schlongs
Hahaha
Hmmm yes thats what i was tryin to say :D thanks for clearing that up for me
* "pops" some pills and goes to gay bar * :down:
hey guys i dont know if youve seen this shit before, but i jsut came across it,
pretty fancy and nicely designed flash site,
http://www.erasus.net/home/index.html
i wouldnt wana mess with them,
i just lol'ed
buhahaha
p.s i recomend you read the pink slip section at the bottom of the wesbite.
cheers
now ask me if I care :D
John look into your heart, dig deep. Can you feel that burning? Thats the care bear knocking on your heart, telling you that you do care about this.
I took a care bear quiz on facebook once... apparently I'm death bear... so I think that burning is actually my urge to kill :banana:
Oh is that what that feeling is . . . I always thought it was heartburn lol
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
