funkymonkey
Josh....i bet the R32 didnt have stupid camber...I know this because you are still alive!
Crazy camber is ok for cars with no power but as soon as you get decent power you start finding ways to get as much rubber on the ground as you can!
you would have needed it that way to actually get power to ground!
Had a similar deal in my r32 was too low and too much rear camber, even at 260rwkw it couldnt get anything down then when it went over 300 it was just shithouse, any throttle at all saw it just going nowhere in a smoke cloud! I raised it a little and got the rear camber set at about 1 degree and it was all sweet!
Hahaha
Hows the 180 going bro, you taken it to the track yet?
not as yet - just waiting on a few "overnight parts" from japan :(
Thats the sound the tyres make because he's a slave to trend and stupid offset/camber
oh no you didnt :banana::ban:
Agreed . . . Too much camber = no traction and shit tyre life.
IMO get some wheels that f**kin fit :P
lol
oh no you didnt ;):ban:
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
