You are easily pleased then. f**ked if I'd pay over $1000 for a second hand POS clutch that may or may not explode at any time.
Can build and sell retail the EXACT same thing for half the price using all new parts.
Astro:
And 3 puk? WTF were you thinking? I hope you don't care about ya neck
explain sir?
hmmmm... looks like I've missed nothing so far...
*scampers back into the shadows**
hahah its a bit like that for me today
Careful tristan The Jewish are after you!
huh jews?
i cant think of a jew without thinking about borat hahah
politically incorrect, but hilarious
explain sir?
Have you ever driven on a 3 puk button clutch before?
What is the car being used for? And how much power does it make/will it be making?
Racist much?
hand over the jew gold, kyle
Side note : Did i tell you's that if i can get enough donations I will be growing a hitler still moustache for movember... but I might call it a chaplin... not sure the jury is out on that one.
nope i havnt, car should be making around 220kw-ish + if everything goes sweet, used as a dori machine
Then a 3puk clutch is a poor choice. Whoever advised you on this needs educating.
You may end up liking it but it is EXTREMELY harsh on driveline stuff. Say goodbye do diff, gearbox and universal joints. You'll jolt your neck every time you take off but it'll kick nicely for drifting. But then again, so will a 5 or 6 puk button clutch but it won't be as hard on everything.
3 puk should be good to hold 350+rwkw, 6puk at 300rwkw and 5puk at 350rwkw.
So basically the wrong clutch for the job
Plus when the clutch wears out you will need a new flywheel. Because from all the clutch riding you are going to be doing while you drive it on the street, it will machine a large deep groove in the flywheel.
*plays dramatic music while waiting for Elite Racing's reply"
I've got 5 minutes spare if you want some lessons. Hmm, on second thought, might need a decade.
I was happy.. Knowing what happened with Noel and knowing what really goes on after reading about parts, not so happy. I was a lucky one. Back in 02/03 when the clutch was bought there wasnt really a huge aray to pick from.. Started with an OS twin plate, shagged it. JB worked, heh.
Not easily pleased, you know this.
you raise a very good point, i didnt take into account my drive line ;)
oh dear :(
I just assumed from the car you drive.
Oops did I say that out loud
Im pleased that car runs. Im a slave to offset. It's in keeping with mud crabs and so forth I guess.
That car now is in better mech nic then half the shit boxes on car sales :(
oh dear :(
And just to clear up what I believe Taz is getting at:
I don't give two flying rats arses who sells you a clutch, installs your clutch or whatever....I am here for advice only, not to pick up work.
I fit around 30 or so clutches a year to Skylines and silvias and have done for the last 6 years. Just telling you how it is.
All my cars have had button clutches fitted so I know what it's like to drive them. I have sold and fitted many to others and can tell you it's hard enough satisfying people with a 6puk clutch (which is AT LEAST twice as easy to drive than a 3puk) when they have never driven on them before. There is only two reasons for needing to go button in the first place.
1: The car makes more than 300rwkw
2: Drifting
Why can I never get a bite out of you? You wanna have sex with me don't you?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
