that seems like a lot of effort to go to...
sounds like you're just out of download and want me to hook you up!
Nah man.. I'm doing the kids of the world a service. I'm trying to get rid of all the pron on the internets. If I d/l it all no one else will have it. Just wanted to give you a heads up so you could get some before i got it all .
ok maybe no martin - that dog is running too much camber :P
HEY! I have nice camber now
Yep got crappy tyres.
Well there's ya problem :P. Naah but as the other guys have said, too many variables. Sounds like you MAY benefit from more front camber, but could be plenty of other things as well.
R33 stocko rims for sale! without tyres! pm!
How much?
heyy... theres a remote on the desk, and a tv mounted on that pillar.
Anything decent on tonight?
Hi Geoff! ;)
I now know why dad was bugging me to come pick up the ute - my birthday present is in the tray :). Pics as soon as I get it out (or find some on the internet).
EDIT:
:D:thumbsup::cheers::banana:
Edited by Smity42
This is all of brisbane water mains.
end lesson
Nope its all carp.
Do i get square eyes? Sometimes :cheers:
1 hr to go til beer o'clock
:thumbsup:;)
I'm actually going to ask a serious question.... I think i'm ill
I recently got coil overs and underbody kit and etc.. Now I've got 17" 235 ( standard size tyres ) after I got the coilovers etc done it scrubs on the guards and understeers like a bsatard and spins the rears in the wet. I spoke to a fella from a tyre place and he said that it would be because the tyres are like this | | and not like this / \. Is that the case here ? Or am i missing something? If the tyres are like | | less traction and understeer ? / \ no understeer and heaps of traction ?
It's possible the camber is wrong but I think you'll find that the spring rates are too high.
What brand coilover?
XA extreme's
Ahh Pedders.
Any idea on the spring rates?
If not, can you tell me the coil outer diameter, number of coils including the flat ground ones, thickness of wire and total height?
Ahh Pedders.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
