ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :D
This tuesday? damn, wish you'd asked a couple of days ago :)
I'll try to get out of cricket, but it will depend how many people want to play
GTS4 ? ? ? Is that the AUS made RB20det wit 4wd ? ? ?
JDM
The GTS4 is essentially a poor man's GTR. When Nissan released the GTR, the Japanese folk who lived in the mountainy areas with the rough roads and snow and crap really wanted them, but couldn't afford them. Nissan built an RB20 powered, heavier version of the GTR. The GTR uses all the fancy aluminium parts for some panels, and running gear etc. The GTS4 uses steel. So basically: it's the standard GTST body (so not wide body like the GTR), with the ATESSA 4WD from the GTRs, single turbo RB20.
GTS4s are less common because it is hard to find ones that aren't rusted out due to all the snow and salt.
Whats planned for it? I have such a soft spot for gts4's. More so when rb20's are kept.
The little motor that could!
For now, probably just a brake and turbo upgrade. HICAS lock out, drift switch. Cosmetic changes.
Down the track I'm going to look at a different engine (maybe a 26)
ROLL CALL!
hopefully some of you guys can help him out :)
If I have my car by then, I will. If I don't... well let's just say I aint walking.
ROLL CALL!
so like just a drive by ?
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
