You saying the word shopping, makes me want to go, sucks that Indro doesn't open till 9am or whatever!
Turbo - I decided on high flowing my Garrett... =)
Edited by Kitty34
Ah k which Garrett have you got ?
It's looking good Dave.
It's almost a roller!!!!!
I have 2 weeks off soon, when does your work hoils start?
Awww spewin I cant see the pics
*punches work pc*
hmmmm seems like all the car sound devoted stores are too spread out. might have to wait till the car is registered :(
Guess I'll just throw my little Panasonic unit in as a place holder.
Hehehe
Have you had a look if theres any second handys going in the 4sale section ? ?
Hehehe
yeah, nothing good there :(
and I'm really picky and greedy lol. I want an SD head unit. Sick of my cds (and copies) getting f**ked in the car.
Yeah, the fast & handling bits have taken all my doof doof money, hahaha!
yeah, nothing good there :)
Yeah fair enough
Mines got a plug in for my Ipod but I dont use it anymore cause the quality was shit running off it.
Ive just reverted back to good ol' fashion cds :D
Yeah, they're all iPod/iPhone crap at the moment :(
I don't own any apple products, so those head units are no good to me. Thinking it might wind up being eBay spec, because the big hitters at the moment don't seem to be making very good touch screen head units. Although, JVC have one that would be awesome if it had SD (fail on their part). And Pioneer seem to have lost the plot and started putting smaller screens on their units :)
*sigh*
Edited by Isola
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
