I'm running on two hours sleep... I'm just functioning like crap.
Ask Tas! lol. he witnessed my complete f*ck up today.
Welcome to my world. If you get this job its like this all the time :D
F_ck up hey...
Do go on,
F_ck up hey...
Do go on,
I've worked in a 24/7 call and radio center.. I know about sleeplessness :)
Let's just say... Don't ever let me touch your sump plug :)
Let's just say... Don't ever let me touch your sump plug :D
That sounds kinky.
Hahaha nice ... *walks away*
Oh AND this is why I need a rear sway bar >.< Got the front today, rear will be next week, hehe! I am currently running JIC Coilovers 10/8's ... I should go 12/10s on track :D
http://i54.photobucket.com/albums/g86/RandomRiki/MSN.jpg
I wish I knew things about stuff and stuff about things.
What you just said made no sense to me :)
Tristan its gods way of saying dont fit turbos before buying ecu ect
yeh - agreed it wasnt ideal, but the original plan was to get the ecu done in a matter of weeks
however shit kept going wrong so the ecu kept getting put off,
its not like i was driving it around - ugh
riki thats a damn land barge, get a rear sway bad and you should loose that, then see about needing stiffer springs
Didn't you read what I said? I am getting a Rear sway bar ... and I have JIC Coilovers running 10ks front 8ks rear and I am going to up it to 12k front 10 rear!!! :D
Edited by Kitty34
Bahaha ... I could do that ... the car is still being set up :) it's good attempting to drift it with each new mod, makes me appreciate when I add something new :) Like I can't wait to put these Cusco solid cradle bushes in on the weekend & my Cusco sway bar + adjustable castor rods :D Then I will see how it goes :D
In other news:
Rims are balanced and fitted. Spark plugs are changed, oil is dropped and flushed, gague cluster is changed, oil filter is changed, fuel filter is changed, blow off valve is changed, pod filter is installed, strut brace has been put back on.
tomorrow = bleeding ATTESSA, filling up oil, installing alarm, installing exhaust.
tomorrow hopefully = registered and driving
:D
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
