hey, just a quick question, would anything go totally wrong if i reset the ecu in my car?
also correct me if im wrong.. disconnect negative bat terminal, pump the breaks for a bit.. reconnect negative and turn on again?
Correct.....nothing will go wrong...theoretically.
I saw you last night
ooo was I coming or going? Had to have Sugo Mi, then went to Freestylers. And it was good.
good news,
keep us posted :huh:
Cool, hopefully they sort it out and it doesn't cost you too much
+1
Won't have the car back today. They need to try and source some parts tomorrow... so hopefully they can get it all and have her ready tomorrow.
urgh :D What parts does it need?
A relay for the fan/ac control, and some *bsskkt* for the wipers (phone reception was shit) sorta sounded like a switch...
Then hopefully the brake lights and reverse lights are just a fuse. And I'm getting them to have a look at the head unit. The dude at JB said it might be because we didn't have the remote wire connected to ACC. But... I dunno. In hindsight, probably should have gotten one of those adapter plugs :huh:
what, there was adapter plugs available?
probably wouldn't have worked anyway, your stock plug was already half butchered from the previous HU install.
I don't think it can be the remote wire, that's an OUTPUT from the HU to the amp. Maybe it is something to do with the hand brake switch wire that we tied straight to ground?
Hopefully they can fix it pretty easy tomorrow
Then hopefully the brake lights and reverse lights are just a fuse. And I'm getting them to have a look at the head unit. The dude at JB said it might be because we didn't have the remote wire connected to ACC. But... I dunno. In hindsight, probably should have gotten one of those adapter plugs :down:
remote wire is for an amp... is there even an amp in the car? If no its got nothing to do with remote wire. and yes adapter plugs is where its at, cause when the Headunit craps out or you need a new one have fun re-wiring it again :D
Yep very lazy...yawn...
Ah toowoomba not much has changed
I'm about to play my favourite game,
D/L pron at internet cafe, how long will it take til im escorted out. :)
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
