Isola you putting a remote start alarm system on your car ? If so, do you know where the relay is so that the car doesn't start in gear ?
*end serious note back to reality*
oh look a duck.
nah, no remote start for me :D I wanted a remote start alarm, but really just needed an alarm in and going to insure the car. Kinda just planned on keeping the mongoose for a while and changing over down the track. Kinda wish I had have just gone with the one I wanted from the start now though. To answer your question - just leave it in neutral all the time like I do :)
my serious question - does your remote start work when the steering lock is on?
*general ramblings and suggestions*
At this point in time, I highly doubt the boot an bonnet pins are wired up/even installed. Figured the doors would have at least been something standard that was done on every car. Need to get it sorted out ASAP though, because my insurance doesn't actually cover me unless I have an immobiliser AND an alarm installed.
Granted I've not yet checked the power steering fluid, but I figured it'd be full because everything else was when I bought the car. And knowing my luck, it's more likely to be the pump. No warning light on though (don't know if there is even a warning light for it on the dash?) Not the end of the world as I hate power steering anyway... it was just that it was one more thing to frustrate me after getting raped by the auto electrician.
Hope you find a unit soon dude. Share housing sucks hairy jew nuts :)
also john - i think ive found those wheels you were after
enkei rpf01
Not them, but thanks anyway dude.
thanks for the input guys. there was something else I was going to say but can't remember... *shrug*
nah, no remote start for me :) I wanted a remote start alarm, but really just needed an alarm in and going to insure the car. Kinda just planned on keeping the mongoose for a while and changing over down the track. Kinda wish I had have just gone with the one I wanted from the start now though. To answer your question - just leave it in neutral all the time like I do :D
*puts on serious hat and pipe*
The remote start that I have will start the car with the steering lock on and if the car is in gear. But with the relay switch if the car is in gear it clicks on and disables the remote start. The relay switch was a option that they put in for me as apparently its illegal to have a remote start on your vehicle if it is a manual as you can start the car in gear and watch it merrily drive down the road.
*removes pipe*
I kinda meant seriously...
no wait nevermind... my mind just processed that I never knew what Dominos she was working at... so obviously that's what it is.
Edited by Isola
john if you want a good auto electrician try toowong car electrics in black street milton, not sure what he charges but he does our stuff for work.
You still got hicas too yer? maybe got a leak in the system there somewhere. I say lock it and new pump to a rb25 pump
Dan - thanks for the tip. I might check them out next time. Right now though auto electricians are on the top of my kill list.
so... for those of you playing along... an update on the FO':
Power steering is probably the belt. We forgot to change it :)
Brake lights - still playing up
Reverse lights - still playing up
Head unit - now wired up and working like a dream thanks to Jack at Phantom Motors :) (side note for Martin & Dan: My pioneer speakers are rooted, so I need new 6" speakers. Just going to buy 4 6" speakers the same and save the headache of trying to get those 6x9s in the doors).
Amp - working fine
Dome light - working
Headlight - still need new globe
Map lights - still need one globe
Paintwork - filthy - car wash tomorrow night? :dry:
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
