Have stock dump, front pipe and cat. Just need stock cat back now
I have a not-stock cat back for a HR31 if it helps :)
don't worry your all on the list.
Can I be first? I hate sloppy seconds :nyaanyaa:
beers for anyone who wants to chuck my boost gauge in :nyaanyaa:
how sexy are they :)
mine is in and running like a champion - no real point or need atm, i just sit in my garage in my car and make flutter noises hahahah
I think Collin should kill the next person that talks about his sister :) . . . starting from now :P
Well that's me i'm dead
beers for anyone who wants to chuck my boost gauge in :P
I can chuck it in for you.. Might not work though. :nyaanyaa:
how sexy are they :nyaanyaa:
havent got it yet, waiting to hear from dave to go pick it up..
is it an easy install?
dave helped me quite a bit as i am retarded with electrics - and in general,
but yeeh didnt seem too bad - the problems happen when you take off the dash to connect to power and you discover that every wire behind it has been hacked to shit and has just been tapped back together
so fixing all that up (soldering/heat shrinking/zip ties/ etc) took ages
my 32s wiring was f**ked as well, hopefully with your 33, and it being newer means the wiring is in good nick :nyaanyaa:
my 32s wiring was f**ked as well, hopefully with your 33, and it being newer means the wiring is in good nick :P
I can be Dave's apprentice. Hahaha I'm pretty good with soldering etc back in uni too. :) Gimme a shout if you guys need a hand again. Dont mind looking at the Legendary Dave at work :nyaanyaa:
did i mention he re-wired my whole dash/alarm/headunit/turbotimer? hahahha
ps i gota show you guys a pic of my burn on my finger - i (somehow) put my hand on the soldering iron when it was at 450degrees! so 1 of my fingers is messed!
pics tonight!
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
