oh man id be so keen for this
f**king work
give me notice next time :laugh:
Bail on work. Its only tuesday, they'll live without you.
We've had 3 ppl bail since lunch time, hard to give more notice :(
I'll make an exception for you if you rock up with a hitler mo
I see the Pom lurking, and poms luv cricket :laugh:
Sorry this Pom plays football only.
yeh the pitch is taking a fair bit of turn....and the delivery that got ponting out seamed back in from about 4 feet outside off and ended up cramping him for room on a square drive...that was pretty nasty and mostly pitch related!
I don't understand any of that...sounds gay though.
i cant sorry mangalicious
you'll miss my epic off spinners and wicked stroke play
ah cricket..
I've heard stories of your stroke play from Josh.
Oh and emos can't play sports.
ooops misread fail! I would say yes but I am so bad at indoor which is wierd because i was always good at outdoor! I think that gay yellow ball is the issue, swinging all over the fekking place :laugh: ha ha
Watto out for 96 and 48 in one match! he is probably thinking FML right about now
You're a miserable pom
LOL!
Yeah the yellow ball is deadly. My (partially blind) left eye will testify
LOL. Unlucky. Whats the odds he gets dropped now for hughes?
I thought u loved me :(
believe it or not i was once an opening batsman and a spin bowler repin the Cs - yes there was lower than the Cs, the Es teams :laugh:
330 was a big ask, im surprised we didnt start playing for the draw straight away
If they were not i would have bought in Haddin after Ponting, then Johnson (when he scores its quick!) Then after that Clarke who could either keep it going or play for the draw with North and Hussey depending on the position they found them selves in
Odds of Watson Getting dropped....slim he would be averaging somwhere in the 50s since opening wouldnt he? and Hughes has not been setting the world on fire in the shield
I can't keep up with you guys... you all too quick
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
