funkymonkey
That sucks...... did you get details for insurance or did they do a runner?
I know the feeling though, my front bar's had so many scrapes and dings out of it, I finally decided to pull it off, sand + bog it and repaint it...... but it's gonna look like total SHITE. To top it off I ran out of paint this afternoon and the shop I use isn't open til Monday, so it looks like I'll be riding my bike to work for the first half of this week!
runner :geek:
col if the idea is small and touch i'm not going to be able to do anything like that HP.
But I'll see what touch screen shit is around and how small a case i can find...
*waits for touch jokes
Nah don't worry about touch shit i'm not goin to go out of my way to have a touch screen lol it was just something I spotted in the Harvey Norman catalogue.
@Dave that is a cool set up. I can always hook up the tower or my old laptop to my tv if the mood strikes.
@John: I don't think I will be able to make it this week :geek: Mum's birthday.
@Colin:
Case Antec Minuet 350 Slimline case with 350W PSU $133.00
PSU ^^^^^
Mobo Gigabyte GA-P55M-UD2 P55 4DDR3 4VRM PCIEx16 GLAN DES2 8SATA 2X1394a mATX $133.50
CPU Intel Core i7 860 Processor LGA1156 2.8GHz 8MB Cache CPU $334.00
Ram Kingston 4GB(2 X 2GB) DDR3-1333MHZ $125.00
HDD Samsung 1.5TB Silencer Series 32M $133.00
DVD Samsung 22X DVDRW Black SATA (SH-S223C-BL) $37.00
VGA Inno3D GTX 260+ (216SP) PCI-E 2.0 896MB DDR3 DVI HDCP $228.00
Monitor Samsung P2350 23 $237.00
OS Microsoft Windows 7 Pro 64bit OEM(Microsoft OEM Terms&condition apply) $169.00
$1,529.50
Will shit all over that HP, but no touch and it will take up a little more room. Although that is using the smallest case I could find. No keyboard or mouse in that shit either - do you need them?
You can shave a bit of cost off if necessary with either a smaller hard drive, windows home edition, or a less powerful video card.
that sounds pretty svveet Martin. Yeah I decided against the HP, just gunna save up a couple of months n then build one at least then I'll get everything I want.
Yeah its not a bad rig at all. If you want to be able to overclock it well but, you'll need to get more expensive ram and a CPU cooler. Factor another couple of hundred there. But really theres no need to overclock it, it'll be f**king fast OOTB.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
