I can has DVDs of it (I think) if you want to borrow them at some stage, but you'll have to wait till I've unpacked
Thanks, but I'm not a fan of the special edition ones. I have the original versions floating around... somewhere. I'll go find them when I hand in my "steal everyone's tax money" form :P
You Guys are so quick to jump on the against Harry's Bandwagon.. :P
If you are open enough to make an effort to actually meet new people and talk to people outside of your little "Icecream Crew" you might Actually find that there are some good people there..
No wonder Skyline Drivers get a bad name..
I remember coming to your Baskin meet once,, And you all sat in your little group and weren't exactly the easiest people to talk to..
So Stick to your little Bum Buddy Crew and do whatever you do.. But dont sit there and say "Oh it sounds like it hasn't changed" When you dont even make the effort to check it out..
I had a great night, Had lots of fun, checked out some awesome rides and met some mad people
Chillax mang do you think anyone takes anything we say seriously? Sounds like plenty of people are going to harrys and there are plenty of people who don't want to go. Ranting and raving isn't going to make any difference to attendance at either event.
dont include me in either groups - as i wasnt there when you were at baskins and i didnt comment on harry's
aaaaaaaaaanndd i have SR POWAAA :P
just curious beck, what time do you guys bail - i drove past around 8ish and it seems pretty quiet..
Dogged us mang. And I came to Brisbane especially to see your tractor. So disappointed I feel you are obligated to come visit me on the coast.
Who cares,
Both locations are just as lame due to a % of clowns going to both,
Some people at Harry's are great, some arent.
Some people at ice cream are great, some arent.
:cool:
Stop sh&t bagging my car to other people then. It’s cleaner and mechanically better than what you ended up buying.
I haven't, and don't, and wouldn't as I don't have first hand experience of the car. So jam your accusations up your ass.
+11ty
+1
+2e369
Stop sh&t bagging my car to other people then. It's cleaner and mechanically better than what you ended up buying.
Even runs in rwd only, like Johns rwd 4wd model.
lolz!
and i <3 your 32
ill come visit you mang-a-licious :P
I have on good authority perhaps someone on here tried to convince you otherwise.
yeah, me :P
So what is it, "yeah me" would tell me you have, but then you said "I haven't".
Use my tax money to sue me for slander or something
I think the yeah me was meant to mean that he convinced himself not to buy your car :P
Where and when
Pearl at Circle on Cavill. Sunday at 11?
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
