Hi Tristan!
Thanks for dinner on Saturday :)
Dan still wants your wheels
you want my sr now :)
aand you guys owe me icecream or something
Yeah! I could put it on the ride on mower, which we managed to start on the weekend despite dad's assurance that it 'would not start'.
I already owe you ice cream, you just need to turn up to collect it
P.S. we got sick of waiting for the cab you orded, so waved one down off the street. Took about 10 seconds :)
who is going to ice cream this week
Me me, pick me!
Might car pool it over with Dan...
Speaking of Dan, I think the lucky prick just got to take the GT-R that was traded in for a spin
yeeh thats baller, cabs are shit on saturdays lol
i will if you will
Me me, pick me!
lucky f**ker
Hi Tristan!
Tristan. Thread needs more pics of your car.
you want my sr now ;)
You wouldn't come to ice cream anyway...dog :)
Ride on eh. Dad is buying an SR to keep the paddock in check at home. Should be sick.
I will if anyone wants to come pick me up lolskates.
tehehehe
we could be in, but only if Tristan is because we dont want to be the only tractor
we could do this..
I'm in
If and only if
Geoff's in
+1
i will if you will
ice cream meet needs MOAR nismoh and GTTG
lucky f**ker
Yer *jealous*
Looks like he'd better this week
This ride on is at least a hundred years old. It was ancient when dad bought it, when I was about 5. It had about a 2.5HP engine which I blew a hole in the side of, now its a wicked 10.5HP. But it hasn't been used in ages, needs major service, new blades, and the cutter mechanism and steering both need some work. But will be baller when it's fixed.
If you jump on a train to indro (somewhere near the city if its easier) I'll pick you up. You'll need to train home or get John to give you a lift or something though.
Why not, everyone loves a tractor.
Tristan, you'd definitely better come this week. Free ice cream, and all the sheep will follow :)
am i welcome? i mean with my "secretdick styling", stretched tyred, lowness, sexiness...
ait andy, nismoh and i are coming - ill talk dave into it too
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
