dammit!
i wanted teh luxury of being able to switch from baller wheels shit house secretdick styled wheels to gay as f**k cool wheels
does the 31 bake yet? :(
31 runs...hasn't had chance to bake yet. See how we go throughout my suspension with teh moniez. Should have it up and running by the time I get my license back.
i <3 the pom
:ph34r:
help me find a turbocharger to suit a 10.5HP briggs & stratton lawn mower engine
Standard SR turbo should work.
Can't give him a lift if I'm not there :down:
Damn. I was considering training it in to Brissy if the tractors n nismoh are going to be there. *Sulk*
We'll see what happens. If I do wind up going to my sister's place I'll probably be leaving there 9ish anyway so she can put my nephew to bed, so I could always just arrive ultra late.
this one?
Do it. Just catch the train back as well
tru dat, im thinking of getting some cash together and maybe swap mine and cash his way , but i doubt i will have the cash or he will want to swap for another r33 gtr which is pretty much standard.
just calculating funds required and if its feasible.
if you want a standard s13 t25 we have one....would be far too big though
naah, really? :ph34r:
If you're giving it away though I'll take it and fit it for lols.
At the moment I'm thinking computer fan with cardboard piping to plum it to the intake and a gel cel is the way to go :down:
Just buy a supra
nah wana stick with a r33 gtr, after i graduate il be buying a R34 GTR and keeping the R33 GTR as well, maybe put some money in to it and make some more power, its in very good condition compared to others, so i have a strong base to work with, but thats a long way down the line, ive been in too many supras in qatar, feel too heavy, i know suprising coming from a r33 gtr driver owner but they are, and they handle like shit, but again that was on the road never been on a track in a supra.
edit : actually if i dont end up staying here then il be buying a R35 GTR in Qatar, too much hassle with coppers and rego to buy older models and its pretty much impossible to register them unless u know the right people or the king, and the few that i have seen all have UAE regos and they drive on that in Qatar, its just very complicated, GTRs are very expensive there considering we dont the luxury car tax theyr still pretty much the same price as here maybe a few grand less.
I wouldnt bother he clearly overvalues stuff
Just buy a supra
yeah man if you can make use of it you can have it at least till you are sick of it
there is a turbo that you can get from jap wreckers, its from a dihatsu of some sort the compressor cover is literally about 3-4inches across, i reckon it would work well
Sweet as, should be a fun way to kill a day :down:
Yeah I've seen em, thats more the thing I was after. Couldn't find any on ebay though :ph34r:
Turns out i dont have a rev limiter..
8k rpm shifts wooot!
Valve bounce that mofo!
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
