MacGuyver would have built one by now :rant:
True, and I am ALMOST as cool as MacGuyver, however I've been busy :ermm:
Might do that but its a pain in the arse.
Do it you skirt
Qatar sucks.
+1
speaking of serbs where is our little serb?
Who me?
probably off working on his lawnmower :P
Naah, went back to the old place to clean up. F*CKING hot, f*cking hard work, I hate cleaning :(
Sup mangin mangs..... so stuffed from work. Time to get my taco on!
sounds mexican...
mangs
bloody hot
:D
mang
yes it is. F*CK summer
So i drove the 35 GTR today, its a good car
I liked it alot.
So jealous. Wheres my promised pics?
i earn that after tax now...and im bad at negotiating but they would need to literally pay me triple to get me to go and live in a hotass desert!
Same, although i'd probably consider it for double. Do they have any race tracks?
when i was there, they didnt, now they have the Losail International Circuit, mostly for motoGP races, but you can have track days on that, pretty nice track,
also just recently built the Qatar Racing Club has international drag racing championships which Qatar has been winning for the past few years with its Al-Anabi team, you can drag there with street cars as well, and they have a massive skidpad too, other than that they have massive dunes you could go dune bashing on in 4x4s,
however dont expect to buy skylines there, you would be very lucky if you could register one, most popular performance cars there besides the corvettes,shelbys,lambos ferraris etc are the luminaSS ( commodore dont know if you classify it as a performance car), ford mustangs are dirt cheap you can pick up a mint 2003 one for 20 grand, the same would cost you around 50 to 60 grand here plus conversion to rhd, rest is all the same but most cars are cheaper due to no luxury tax.
you know what i dont like?? the only pics i can find are either guys standing in the desert or concept drawings of things that do not exist
I love watchin arab drifts on youtube..... especially the bicyle one/s lollllllll
EDIT:
for hilarity!! Edited by mosquitocoils
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
