Dlink G604T or something like that.
Nah its a splitter thingymabob with the two outputs and it is plugged into the adsl one. Was thinking it could be shitty phone lines in the building as it's 20+ years old. But still going to call them today.
The G604t is what I've got as well. I'll probably never buy another dlink product again but the modem I've got is alright I spose. The splitter you have connected, does it have a phone line connected as well to it?
Michael Atkinson is a cocknugget. Just throwing it out there.
http://www.theaustralian.com.au/news/natio...f-1225819431495
Someone please bash this guy in his vaganeous.... The censorship in australia is an absolute joke....especially with games
Nah no phone line connected to the splitter. f**k home phones.
dead thread is deader than dead. You mangs need to manging get your mang together and put in some mangalicious manging in the next manging mang for mang sakes. Mang.
*face palm*
fag
Yes!!
Let there be life.
YES!!!
i think martin wants to be the star fish this time!
YESSSSSSSS!!!!!!!!
Yay my internets are now connected :(:D
Mad props to tpg/telstra, took a whole day off their 10-20 day estimate (9 days)
Only thing is... now I need to work out how to connect my PC to my router. Need a wireless card for PC...
i rock Cisco and belkin products.. because its baaalllleeerrrrr
cisco is baller. Belkin is pov pack
would you be the one doing the fooking?
whatever you like hun ;)
How does get f*cked work for you?
<3
LOL
And Iphones in the ass i say. Stupid phones they can all get f**ked
GAY
You mang are a poetic mang.
*face palm*
fag
GAY
Poof. :kiss:
Oh you, :D
+1
you guys on estrogen supplements or something?
You talking about tas, again ?
Shaped plans ;):(:down::down:
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
