I have a mate that runs his own spray shop if you have no luck with that guy let me know and i will see what my mate can do for you, he loves custom stuff
Oh yeah that would be awesome, I need to find out if its possible to bring the rear gaurds out about 20mm and how much ide be looking at?
step 1: remove skirt
step 2: put on pants
step 3: come to baskins
step 4: PROFIT
Mate is giving me a lift into brissy afterwork so one of you fags can drop me at some station after baskins.
is it wrong that i used the word gingerly in an email to a client?
Yes don't be a racist.
Yeah can do. Or if I get a lift with Dan, I'll force him to.
Ginger is a race now ?
They're kind of like a sub-species. Semi evolved/mutated
:S
I like your style :D
I salvaged it from one of my mate's parent's place when they went ducted, its massive and loud and covered in fauxwood panelling but wow does it ever get that garage cold!
oi yo martin, and anyone else who cares..
turns out the 180s ecu was chipped from japan..
so instead of her going on the dyno to sort out timing, she went on the dyno and got tuned :):D
AAAAANNNDDD
shes a f**king handfull to drive now :D
:D
Yes
Win
Should I buy a 6kW window mount A/C Unit for the garage?
Yes
so instead of her going on the dyno to sort out timing, she went on the dyno and got tuned :D :D
AAAAANNNDDD
shes a f**king handfull to drive now :)
You coming tonight? I'm coming all the way to Brisbane I demand some 180 luv
Working on cars in air conditioned comfort certainly sounds good. I'll just need a 15A socket put in the garage for it...
AAAAANNNDDD
When do I get a drive?
yeeh i guess i might come by briefly, shes going to struggle over the speed bumps lol
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
