hahaha.. lol.. I guess your looking for a bit more then a laugh arnt you...
obviously plug and play meaning you dont have to go through the hassle of getting the tuner to chop up your loom to wire in the E-manage or Haltech thus creating a large bill at the end of the day
Thread needs more nuts and bolts.
P.S I love andy
sexy
there are plug in looms for haltechs now, making a power fc even more redundant
+1
a pfc should never be tuned with just a HC
Also PFCs are f*cking ancient. Do these people run 486s with their 18k dial up modems to connect to the interwebs as well?
you know where ill be when u get peckish
Oh tru? That might help decide.
What elso might help decide is I haven't found an antenna cable to hook up the TV yet :P
:rofl2:
Also vipec plug ins :domokun: There's simply no good reason to buy a PFC any more
I'd like to do things on the cheaper side for RIGHT NOW, but I can save for a PFC or whatever.
Obviously it's not simply plug in and boost your nuts off, but it does sound like a better option (so much easier to wire in hahaha). Then drive sedately to wherever/whoever to get a proper tune.
Other option I was leaning towards was a Nistune... even easier... and I can't see me adding too much extra in the future, so its an option.
Really all I want is more torque in the lower RPM range... It's only a streeter so I'm not fussed up high, cause it rarely gets to go at full song... I'd just like to be pushed back in my seat sooner :domokun:
Thanks for the PM too Tas
Even some model of SAFC would be able to give me a boost down low... for a far sight cheaper still. Any comments on SAFC/2 performance? It's only about 5 wires to splice in isn't it?
I dodnt think they control timing? Timing is what will give the greatest gains down low
agreed, and well priced too
Really all I want is more torque in the lower RPM range... It's only a streeter so I'm not fussed up high, cause it rarely gets to go at full song... I'd just like to be pushed back in my seat sooner :rofl2:
go nistune or haltech or vipec, oh and im sure andy will rave about adaptatronic (or whatever its called) :domokun:
two good reasons and only two
Price point and the amount of people who can tune them, with ease.
Second point is of no use unless you've picked one up cheap.
If you only paid what they're worth (SFA), it's a far better option than a stock ECU, don't you think?
I had to grinder the nuts and bolts holding the lawn mower blades on. Stupid rusty POS
Save for anything other than a PFC
my GTR came with a power FC it eats me up inside everyday knowing that my car is run by the atari of the ecu world
LOL. big <3
Sell of it to one of the many nuggets who still think they are the ducks guts, and then buy a real ecu.
I wouldn't bother.. very limited tuning from an SAFC
adaptronics are only great in 4cyl applications at this stage, but for 4cyl they cant be beat!
LOL. big <3
thats the plan the power FC and the two z32 AFMs should pay for about half of the ECU i want
Second point is of no use unless you've picked on up cheap.
If you only paid what they're worth (SWF), it's a far better option than a stock ECU, don't you think?
Finding a tuner is a minor issue. GOOD tuners can tune more than just PFCs. It's just a matter of finding a GOOD tuner that can tune your ECU of choice.
As for price, meh, they all seem way overpriced to me for what they are. But yeah if you get one for a good price, definitely better than a stock ECU of course.
Most tuners I talk to now dislike the power fc because the tuning software is old and shit too, was good 10 years ago, but a lot has changed since then
Of course most are over priced, but say you paid what they're worth ($500 with HC) than paying $1500? for something much, much better.
EG: my basic car, 500 + tuning seems more appealing than 1500 + tuning
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
