thanks for the reply.
big bottom end would be an understatement :D
Cheers Josh - I forgot about Eug.
I'm looking at Bride Euro II, I think they are 99% same as 33 or 34 GTR seats??
man up and go fixed back :(
yea it sucks being sun burnt on ur back
but its ok.. reeling in 60+ cm mackerel is quite fun
if we used a better boat we could go on the otherside of morteon island and troll for huge ones
i might be going tonight.. doing a 3am launch mauhaha
Hai five!
Think I shall detail the car today.
Hai five!
I spent the day installing Air con units :). One in here is now rocking good (although the mount and shit need paint, and it is currently sealed with duct tape :banana:), one in the bedroom I just need someone to help my lift it up and in.
Air con for the massive win, however it was farkin hot out woodworking all day. Worth it though :(
blah blah blah purge blah blah
skinny emo f*ckers...
sif you would want to be a 45kg girly man, my knob weighs more than that...true story
LOL
g'day :D
I'm "working from home" today :D
and SAU isn't blocked here!
Nice One!
no one else seems keen on our epic scheme
No one else is a stoopid emo
I dislike swear filters
+1
I want to see if i can ebully him into weighing less than an average human skeleton
He'd have to put on 5kg...
So f**king hot outside, I was going to clay, polish n wax the car but it is just too f**king hot. I'll just watch some poker videos instead lol.
+1. See above :banana:
Edited by Smity42
pics of your sister or ban.
+1
I've seen her
Win :D
+1
agreed
+1
I'm the biggest e-bully/troll out there.
Tis true
nismoh im sorry i just ate kfc :)
and it was too delicious to purge
LOL. I just ate kfc too :D
my engine is coming out tomorrow....excite! :banana::banana:
Putting a dirty ESSSS ARRRRRRRRR in?
Reporting in
Reading you five-by
man up and go fixed back :)
+1
Sunburnt ftl.
At least when u burn, your skin matches your hair :(
Edited by Smity42
LLOL HAHAHAH i never thought about that one..
good one smity
lol
Which part are you talking about? He made like 17 zings at once in rapid-fire...... my head's still spinning
i have heard him mocking us
saying such things like "hahahaha i have the lightweight and the rb25 mwahahaha"
such a dog
and the highflow vl turb with t3 or t4 cartridge. :D
and im 41kg f**k get it right.
edit: josh msn more often
Edited by 32_Dave
Hahahahaha Dave the difference is our car's are driveable :(:banana:
miss understood previous post i see. (yoda voice)
you dont think i know already :banana: motor in next week after the brake lines are sorted :D
Fuuuuuuuuck yeah..... how much to go after that?
get motor running. bold up diff / drive shaft. bolt in seat take for test drive down street.
lol
but seriously.
- get brake lines (front solids and hydro handbrake)
- get motor in
- finish running gear
- finish wiring
- install all interior back
- paint 2 doors, bonnet, front guards, rear bar, reo's & bootlid (whenever the f**ker arrives, custom FRP bootlid)
- re-glaze entire car
- engineering, wheel alignment, rwc
- rego
- drive for 1000km let it all settle
- iron out problems
- TRACK !!! and beat it :D
the painting is the time consuming shit.
Edited by 32_Dave
painting is over rated
i was thinking tow it to track before its all done and hack it but everything wont be run in / bedded in etc... and ill have small problems that'll ruin a good night. :D
I thought cupping was more in your line. :)
He is good at it :)
Ill fix your back :(
The only thing I cup is a perfect short black in the mornings.
Coffee coffee coffee, oi oi oi, coffee, oi
Liar :)
lol
but seriously.
- get motor in
- finish wiring
- rego
- iron out problems
Lets fast forward to the :) ?
Yes . . Yes it is
P.S. Morning all :)
Thank you for everyone !! I have send the ticket to the transport and wait for them to put into the court!! I don't expect they will let me go easy but at least try my luck see the judge will believe the true or not!! Thank you again for everyone effort!!
ENGLISH FAIL
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
