I would have thought that would definitely be cause to put an SR in
You're a good friend :P
She talks too much. Shut that bitch up :P
So you feeling anymore love for the GTR yet or you still thinking of selling it?
I will probably still sell it, isnt even back on the road yet and its giving me the shits, but i do miss the sound of it and the acceleration off the line so maybe when i get it back it will convince me. I saw the turbos and dump pipes out on the floor when i was down there yesterday and i nearly jizzed in my pants so that was a good start to it winning me back
if only i could
awd is for girls, just run it to rwd with a standard sr box
If that was the aim i would just sell it and pour the money into Annas car! it is already RWD and SR :P
And AWD is f**king awesome 300rwkw in my last r32 was a waste, in the GTR its just enough!
hard to argue with that logic!
Why can't you?
You're a sick f**k you know that right?
The logic is strong in this one hrrmmm. For the loss SR20 is hrmmm.
Yes :P
+1
SR20s are cool, just not in GTRs, they belong in s13s and smaller!
and farming equipment!
And on another note driving around collecting parts is exciting, its been years since I trolled the classefieds ect ect
mmm tis fun
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
