Grrrrrrr can't get damn cat out..... it's held in well with studs + bolts. Got the bolts off but the studs it seems are welded to / are a part of the cat.
Any tips?
Do I have to remove the whole back section of the exhaust to get the cat out? I think I just realised this to be true :P
just work with the wiggle room
exhaust is on hangers, should be able to move it back a bit to get the cat out
its a c*nt of a job on my car, thats why i decided i wasnt going to swap the decat pipe in every track day after doing it once
LOL, found dad's old paperwork for the ride on:
He bought it second hand in 1994, and it was old then:
'twas an 8HP apparently (I thought it was less) but that engine blew up.
He bought the new 10.5HP engine in 1998, at the time it was the biggest one we could get that fit:
I'm not sure how old the mower itself is exactly but I did find the instruction book:
If you look down the bottom, you can note the SIX DIGIT phone number.
Now I remember going from 7 to 8 digits some time in primary school, but 6?
Some quick research, and this very informative page tells me that "Brisbane went to 7 digits in 1975". Therefore, we can conclude that the beast is older than 1975. Thats 35+ years!
And note: it is a mini tractor, not a ride on :P. EEESSSSSSS AAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!!!
Look, you can (could) even get tractor attachments for it:
Definitely needs turbo love
Don't talk to me about ride on trailers, made that mistake once, hung over after new years, we decided to ride in the trailer to clean up the mess we made couldn't find the holding pin to keep it on, going down the hill very fast and the trailer popped off, catapult anyone?
bugger
we could MAKE a trailer for it
matter of fact, there is a small box trailer in the back yard I doubt has any chance of ever getting road registered. Could convert it to a tractor trailer
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
