funkymonkey
So I sat at home, waiting for Telstra to once again come out and fix up the bollocking they did to the phone line. "We'll be there between 10 & 2" so I've been here, all day... waiting. I call them up at 5 past 2 to ask what's happening and they say "No that's booked in for the 23rd, not the 22nd". So awesome that they booked it in for the 23rd and told me 22nd. It's just lucky I don't have a job to go to!!!! :thumbsup:
martin did you end up buying rascovs car?
No, If you followed the thread properly you would know this :thumbsup:
I was trying to organise to go and look at it on the weekend, but it was proving difficult because it was at his fathers place (past d1ckswich), and because he already had another bloke interested (another guy from the 31 club, lol). In the end I offered to come look at it sunday and bring cash + car trailer with me, so then he rang the other guy and it seems he's committed to buying it. So I miss out :D
I like this idea better than cardboard <3
Group Buy?
Welcome to telstra. Felt so good giving them the boot and going to naked DSL...
Group Buy?
I'd be in for a group buy. Can you make an Emily one too? And a Molly?
What naked plan did you pick? I had a look at them but they all look like shit plans.
and:
Edited by Isola
you're naked?
buttsecks?
keen.
You don't ask much do you? Spose I'd better throw a Grace one in the mix too...
http://www.tpg.com.au/products_services/ull_pricing.php
I'm on the $60 one. Its $10 dearer than the equivalent non-naked plan, but remember you DON'T PAY LINE RENTAL ($30). Install fee is a bit dearer, but you come out ahead after a couple of months. Only catch is, you need to have an active phone line (on telsta infrastructure) when you sign up, otherwise you have to pay about $200 to connect then disconnect one (I think I managed to avoid this by transferring my account from st lucia to petrie, thus avoiding all connection and disconnection fees). They haven't charged me any fees that I've noticed anyway...
and:
This picture won't load at work. Hopefully that means its good enough to get blocked by the filter, and I'll get to look at it when I get home :thumbsup:
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
