E30 M3 is too old for work, I cant afford an E46 M3 out right and I refuse to get a loan and I don't think i'd be 100% happy with an E36 M3 (3.2 6spd spec).
I want an SUV, Range Rovers are too much for me to buy out right
Seems pretty logical. Apart from the wanting an SUV but too each his own. Defects manager chick is looking for an X5 atm or the merc equivalent.
X6??
Whats that? If I'm in Brisbane I'm in!
X6 WTF is the point of an X6 btw? They are completely f**king useless...
explain?
E30 M3 and then using it for work would be :)
I'll come along to watch you all make fools of yourselves in the zorb..... and maybe rip some skids in the big field you go rolling down :)
I won't be Zorbing it up either. Let's do skids together!
explain?
E30 M3 is too old and too rare to be using on a daily base - everything about them is a bit of coin to replace and high kay, daily driven ones are never worth the same
Got any idea's - must be euro only
oh ok then. Thought you meant it was some work restriction.
You just made a friend
No zorbing? lamers...
You just lost one
just about to take my dad to the bowls club...
http://www.asio.gov.au/surveillance/meet-our-people.htm
im going to apply :)
That.looks.f**king.sick.nuts. I am f**king going to apply!! Once I find out more...
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
