funkymonkey
Lend me your eyes, oh posse!
I left work this afternoon, turned a corner (albeit somewhat sideways?) and went up the hill, never more than 65kmph... speed camera truck on opposite side of the road, on the side where traffic would be going downhill.
It flashed as I was coming up to it :D
Do you think its possible the guy inside set it off manually to get my plates etc?
OR is it more likely someone going the other way was speeding at the same time? Which side of the road/which way do they face?
EDIT: Yes, dumb, I know... shouldn't be doing stupid things.
Edited by mosquitocoils
They for the side of the road they're on - you should be fine.
OR - they take photos of the traffic going the same direction that their camera is pointing (usually the same side of the road they're on - but I've heard of some vans that have 2 cameras)
But I still think you'll be fine.
why did u want me to go home?
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :D
Hmmmmm thanks for that... yeah I just hate the feeling in the pit of my stomach right now :D So dumb hahahaha ah well
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :O
What do you need sockets for? Removing crossover pipe + coilpack cover etc? Or are you without coilpack cover? If you're without then you just need a phillips head screw driver... although you've probably thought of that already hahaha
unlucky. I can probably give u a lift if you need - call/sms me if you do as I'm about to p*ss off
It's driveable (just) so don't need a lift, thanks though!
removing strut brace, crossover pipe and blow off valve.
got allan keys and screwdrivers. Thought about trying it with my shifters, but it'd probably take me all fkn day
so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
It flashed as I was coming up to it :blush:
they can get you on both sides of the road. old boss got done by one with me in the car. camera was on the other side, flashed as he went past doing 70. got the fine two weeks later.
good luck. hopefully it was for someone on the other side.
That compressor looks bad ass :blush:
Don't the cameras have to point the same direction that the car is travelling though?
    • From memory and please correct me if I have this wrong, the nismo that come with half shafts are specific for that diff centre. You may be able to find Nissan ones that match up but you'd need to understand what nismo are doing.    Best option is get  a pair of 5x1 axles, they usually don't cost that much and direct swap over for the 3x2(6 bollt)
    • AFAIK, the length of the shafts has NOTHING to do with the ratio of the diff.
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
