And on the second day God said unto John PUT THEM ON THE CAR BIATCH. And through God's fury John saw the light and all was well.
And on the third day God said "Silence the dirty ranga!"
and God saw that it was good.
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
Dear Martin,
here is my "blueprint" for my BOV shield that I was trying to explain.
As you can see, it lets more air through, but still not enough to totally let the valve open and release all the air before it goes back to the turbo, enough that it would probably avoid a full flutter though, and just do a flutter dump and make it a stuttering hiss instead of a sigh.
One day when I'm not lazy, and can steal Jason's tools again, I'll give it a go and tell you if it works.
Big <3s from your Advan Brother
im so f**king dnrunk omfgggg
i <3 SR and everyone who helped me put it back in for the 2nd timeee
omg this sceen is f**king ubrly as f**k
ps <3 marto an dan and dave ooomg
I has an angle grinder...
Gaids :D
+1
Just got home/ going to bed/ updated my sig poast!
I got home and thought about your sister, that UPdated my post :(
what about the beer and the chainsaws?
+1
Dear Martin,
Mine does not have that bevelled section or the second hole (from memory anyway). It's just flat, like the Left hand side of yours in that pic on both sides. Strange, maybe mine is actually a 32 item or something. Wouldn't surprise me, that sped Erin ripped me off on the motor I'm sure he wouldn't be averse to putting a few 32 bits on there...
<3 Brother
P.S. Thats now officially 2 cars that I think look good on advans :blink:
Marry me, you sexy beast
Edited by Smity42
Martin, if you need some one to fix your paint up let me know!
Thanks Mate, yeah I definitely will if I can't sort it out!
He should definitely repaint the filler panel for me: if I wanted paint with runs in it I could have done it myself!
The front bar might be more of an argument, since theres nothign really wrong with it other than being a very average job :(. Might need to get your mate to re-do it for me, I'm not going to hand over any more money to this guy.
cool not a worry
John those wheels are lookin good........ and yep needs more low now hahahaha = $$$ :(
Tristan you are a god <3
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
