Yes it was :thumbsup: They flew right over the top of the work carpark
I'm still astounded they had 4 F-111s actually flying!!!!!
where is your work?
I captured them in film, and a russian spy plane circled in red! :cool:
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
And God said unto John "You have not yet discovered it, but your suspension can drop up to another 25mm. Get the Pintara Twins to help you, and you can have the low. You need to buy nothing else except drinks for the boys"
Without knowning what that bypass hole actually does, yeah it looks like it will work
It goes up over the top of the valve seal, probably just to allow some air to always get through even when the throtle is open
Totally saw the new air force jets today...it was ummm..awesome?
I missed it :thumbsup:
where is your work?
I captured them in film, and a russian spy plane circled in red! :thumbsup:
Northgate/Virginia
I believe that russian spyplane is they mighty hawk.
This weekend is reserved for working on my pintara
I missed it :cool:
Sucks to be you
Edited by Smity42
Correct, people block it for some reason, i have no idea what it is meant to do either way, a mate blocked mine on the R33, it made no difference either way
John give me a call on sunday, i'll lower it. Did you swap the rims front to rear? needs pics of it now?
I officially hate work, it is gayer than gaids, i'll be stuck here until 8pm i think
Sounds good to me! Rims are swapped - pics to come once I finish cleaning the house, looks mad now. Need some epic guard rollage though as now I have scrubbage issues on hard corners. We'll have to enlist the services of your friend who accepts beer as payment :thumbsup:
working till 8pm on a friday is certainly of teh gaids :cool:
@Dan, can you paint tomorrow morning? Early as possible?
Also, do you have any epic blue paint left you could do the ends of my strut brace with? (This doesn't need to be tomorrow).
I will try man, im stuffed from work not sure what time i will surface tomorrow.
told work to stick the job, i ain't working 9 hours tonight
Thanks guys :thumbsup:
I'm happy as with it :cool:
oh and the tyres are ZETUM. Apparently the same as R37 Khumos, just with a different name printed in the rubber. They grip well, and they're not noisy. The test now is longevity.
Dan - what's a good time on Sunday?
damn now them pics are making me wish i kept them now lol lookin good
john lets cut your springs ;)
just saying...
itd go from awesome to f**king epicly awesome with 4 swift cuts with my angle grinder
I can get another 25mm out of my coil overs before we have to do that :)
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
