Yes it was :thumbsup: They flew right over the top of the work carpark
I'm still astounded they had 4 F-111s actually flying!!!!!
where is your work?
I captured them in film, and a russian spy plane circled in red! :cool:
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
And God said unto John "You have not yet discovered it, but your suspension can drop up to another 25mm. Get the Pintara Twins to help you, and you can have the low. You need to buy nothing else except drinks for the boys"
Without knowning what that bypass hole actually does, yeah it looks like it will work
It goes up over the top of the valve seal, probably just to allow some air to always get through even when the throtle is open
Totally saw the new air force jets today...it was ummm..awesome?
I missed it :thumbsup:
where is your work?
I captured them in film, and a russian spy plane circled in red! :thumbsup:
Northgate/Virginia
I believe that russian spyplane is they mighty hawk.
This weekend is reserved for working on my pintara
I missed it :cool:
Sucks to be you
Edited by Smity42
Correct, people block it for some reason, i have no idea what it is meant to do either way, a mate blocked mine on the R33, it made no difference either way
John give me a call on sunday, i'll lower it. Did you swap the rims front to rear? needs pics of it now?
I officially hate work, it is gayer than gaids, i'll be stuck here until 8pm i think
Sounds good to me! Rims are swapped - pics to come once I finish cleaning the house, looks mad now. Need some epic guard rollage though as now I have scrubbage issues on hard corners. We'll have to enlist the services of your friend who accepts beer as payment :thumbsup:
working till 8pm on a friday is certainly of teh gaids :cool:
@Dan, can you paint tomorrow morning? Early as possible?
Also, do you have any epic blue paint left you could do the ends of my strut brace with? (This doesn't need to be tomorrow).
I will try man, im stuffed from work not sure what time i will surface tomorrow.
told work to stick the job, i ain't working 9 hours tonight
Thanks guys :thumbsup:
I'm happy as with it :cool:
oh and the tyres are ZETUM. Apparently the same as R37 Khumos, just with a different name printed in the rubber. They grip well, and they're not noisy. The test now is longevity.
Dan - what's a good time on Sunday?
damn now them pics are making me wish i kept them now lol lookin good
john lets cut your springs ;)
just saying...
itd go from awesome to f**king epicly awesome with 4 swift cuts with my angle grinder
I can get another 25mm out of my coil overs before we have to do that :)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
