Looks good mate. :)
I missed out on the planes also... stupid things woke me up. So i looked out the window and shook my fist at the sky.
Thanks dude ;)
I might have to see if my brother can get me a look at them on the base
Sup mangs...All I have to say for tonight is that women are psychos.
Got cornered by an 'ex' (we only hooked up a couple of times) last night at a bar who went off her nut at me for hooking up with someone else at said bar. I mean she was making a f**king scene out of it lol. Was hilarrrrrrrious. I didn't even know she was there... and then I kind of did it in front of her still without realising she was there, watching... hahahahahaha
How bout mind your own f**king business though?
On a good note, I then spent the whole of today with this girl...... I'm in <3
slack bish :)
you want a guitar lesson tonight?
What night ?
Anyone up for German club tonight?
I'm out
I'm bored... someone do something interesting...
Look a moth!
awwww loves
boring ........................... :P
Thats what she said.
+ 11ty for women being batshit crazy.
Amen to that.
Yep, I'll drink to that. women are barmy.
Where'd you go out last night, Rav? I was at Friday's... now my wallet hurts. =/
:O
Hey Geoff!
ravi post pics on facebook so we can share the love here!
ba hahahahahaha
Ok can we please post pics from my facebook? Only friends can see them on there, but on a public forum like this it turns me the f**k on
he sounds keen to me :O
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
