Going to EFI would even make baby Jesus cry
*shrug* they are the best at what they do, it took a long time for me to find some one competent in diagnostics
oh and VGs are ballz :)
the fact that these two comments are backwards from the truth, prove you're on drugs ;)
the fact that these two comments are backwards from the truth, prove you're on drugs :)
the oscilloscope proves that all I am saying is the truth!
cr4p. What was I meant to get again?
I'll have to get dan's too, since hes gone out west
How many GB are required for your bit?
5.5ish gig from memory
you were supposed to get S1 and Dan S2
Just got an invite to a group on facebook called Save the Regent Cinema or some bullshit like that. GODDAMN HIPPIES f**k OFF!
I got that too. *ignore*
I did save the mad picture of Queen street though :cool:
Hippies standards for what qualifies has a historic/iconic building are getting lower and lower. The real regent theatre was torn down in the 70s to make way for that shitty cinema so congrats to them they're only 40 years too late. Our proposal keeps the exterior, entry and foyer which are all pretty cool but I don't see the attraction of the shitty cinemas inside. Does anybody go to them?
no
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
