Yo.......... didn't get that post before. Nah I'm going to bed righhhhhhhht meow. Gotta be up early. Hope the ice cream was good!
evening all, the tatooed GTR is sweeet, sooo much work. not so much the lambo, just cant see someone setting to a lambo with a paint pen.
on another note, any weekly meetings going on around here still? will be in brissie for the next few weeks and keen to actually catch up with some of you guys and gals.
another pike from me. sorry boys
got given a case of actual french champagne as a wedding gift that we decided to get through tonight.
mission accomplished
night bitches
random breath tested tonight...... twice good thing i decided not to DD tonight.
Oh and Andy i like boobs, don't tar us all with the same brush.
and @ little korea boy.
Holy crap that's impressive for a guy to be able to sing that song so well, and still sound like a guy! I was thinking it was going to be like that huang guy from idol or something, just a complete abortion... but holy damn. Impressed!
And yes, it does look a lot like Tas. Karaoke at the workshop? lol
shoulda suspected something was up when I found a whitney CD in his car. nga's been practicing on the sly while touge'n.
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
