funkymonkey
Maybe I should say "make sense" then...
im - Instant message
n - 14th letter of the alphabet
ment - suffix. makes no sense as own word.
guys (plural) - being only a single sau member... not understood.
is this one... or two tenses?
God I'm bored...
HAHAHA ok ok sorry ill do my best not to do that from now on :ermm:
lol that guy wants $1500 for a set in 17" with average offset and only 4, and doesn't get the amount of abuse josh did for having 18" in good condition, good offset and 6 of.
Yer martin i know where to start removing weight from that thing, side intrusion bars, with the cage in you won't need em, then we can swiss cheese the rear side of the door and use alloy for internal door skins, i'll show you on sunday when we get it back to yours. As for the engine, let me know asap about it, i'll try get the bloke to round me up some other parts we will need, exhaust will probably need to be a custom job from the manifolds though, as it is a FWD setup at the moment, its going to be a fun buildup though will be a big learning curve away from the nissans. Oh and its a 2005 model engine so its the Euro4 emissions setup, so 1 cat on each exhaust manifold just at the head, then 1 on each pipe coming back, so in total 4 cats, and from memory 2 mufflers and a resinator. I'm trying to get the GTA heads with the cams, send them in to the machining shop to get flowed and repaired.
John, that facebook page makes me want to start writting a hit list, they are the types of drivers that will on purpose, try to hit you. They are also the type of driver that comes off with dented doors, bare metal scratchs, missing wing mirrors and broken windows and in one case on a 4x4 2 slashed tyres (not the easiest thing to do at 40km/h)
I mostly ride on the footpath, but when i do have to ride on the road its normally only in the designated bike lane or a parking lane, i have still had people in free flowing traffic drive into the parking lane to "scare" me, these are the dickheads that have repair bills after.......
My new helmet should turn up on tuesday, full-face WW2 German fighter plane spec.
Hence, my one man war.
Wound up going with the 109 helmet huh?
yer, it will suit the theme at work, i might end up getting the other one at a later date too. At the moment there is other bike parts i need to get so i can get out riding seriously
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
