TRD Laser :( wicked
So I read this...
but all I really got out of it was:
Dammit! really wanted to go to the baskins meet but now can since i have to get my car towed back home and take the engine out to check the rear main seal and the clutch, the reckon with the clutch the pivot ball is too long for the os Giken twinplate i have in there, does anyone know if there are different sizes of pivot ball for the gear box's? i thought they were all the same sizes? but the thrust bearing carrier is really tight. the box im using is the rb25det from a r33?? are the 32gtr pivot balls in their gear boxs smaller does ayone know?
so... I don't know the answer to your question, but I do have half bar.
HAHAHAHAHAHA not to helpful tho but thanks :P
Edited by 8znR33
Yeh next week.
Drive me - It will be hot.
lol u come to my house next thurs and ill drive yours :(
Hey hey hey heyyyyy....... no Ravi love?
Only if i get them, being the 22nd is my bday
You have to attend to get them
I'll come to next weeks one if Astroh comes
Sounds like a winnar?
lolzzz
im out for this thursday (fixing car) - next thursday could be the G-O :P
I'm getting excited :(
Yeh next week.
If you two build up my hopes this much and then don't show I'll be so disapoint.
Dunno if the bab5 watching is on tomorrow night or not yet... but even if it is, I'll swing past late to see if you're all still there (provided I'm still capable of driving).
I like the cylon car there John :(
I like the cylon car there John ;)
cylon car ?
did i miss something ?
:blink:
I'm getting excited :blink:
We'll be thur, tight jeans and all
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
