funkymonkey
and for the rest of the thread:
Happy birthday Josh and Tristan
I'd probably go along to wherever you're playing football to watch/socialise/eat food while you all run around.
Good luck with the roadworthy ravi. Bring it to BR so we can check it out. And bring some bitches for Martin. There's only so long he can watch through the window before they get a restraining order.
get your tractor fixed thristian?
Yeah I reckon somewhere northside but closish to the center of town is your best bet for footy
yeh mate got it all sorted - gasket fitted, front pipe replaced :) - the jap front pipe fits sooo much better than the cheapo china one that was in it
Martin these are the wheels I have at home. They came off my 33 when I bought it. No idea on offsets but I'm pretty sure they are 8.5 wide. Are these the same ones you were talking about last night?
edit: mine are 17s aswell. the ones in the pic are 16s
zomg sell/give me a pair?
Happy birthday Tristo...
The laser's having a roady done today so fingers crossed hahaha!
thanks sexy
excited for car trips next week?
so, when we're playing with pipes :D
pipe work is done - i think i want twin pipes, im 90mm under the car, but the cannon puts it at 70mm - twin pipes would fix that and look uber lolzz
Yeah happy birthday Tristan!
And happy birthday for yesterday for Nismoh!
<3 :ermm:
Yeah forgot about that. Happy birthday Josh n Tristan ;)
i wnat to touch you
Well it phailed miserably. Got a list to look at, usual crap like brakes, seals (oil leaks etc), one tyre blah blah blah... most of it I should be able to do myself, but rear main seal? Really??? Never taken a box off before, but I'm willing to try... opinions anyone?
Also front and rear link pins? Don't even know what they are lol
pipe work is done
i wnat to touch you
gearbox rear main seal? f**k man - front wheel drive boxes are a joke
replace the tyres and brake pads, and degreze the engine bay then call me :)
no idea wtf link pins are :ermm:
no idea wtf link pins are :)
I had link pin suspension on the front of my '73 bug. The '67 had link pin front and rear.
That's probably what they're talking about.
this is what the front of my bugs used to have:
Does the TRD Laser have something similar?
Edited by Isola
I wish!! f**k I want a dune buggy now!!
So I found out it was the link pin bushes (ends of the swaybars) and a kit for the front or rear is like $20... so I have one and will attempt it this weekend, should be a piece of piss.
Got the brakes too and all the other little things like the clutch rubber thing, nice solid battery clamp wah wah wah.
And yeah I'm gonna degrease the underside around the rear main seal, but the front crank seal + belts, idler blah blah are all gonna get swapped anew when I get some spare cash in a week or two, and that should see me pass roadworthy as the front crank seal + cam seal were the worst offenders for oil leaks. No so keen on doing it myself.
Yes, hub centric bolt ons a perfectly safe. In fact, CAMS rules state you can have 1 spacer behind each wheel.
Just queensland transport that are gay
well sweet as then :) let's go put some cars up on bricks :)
dude hit the engine with degreaser and the next day take it back, or take it to a different place :)
Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
