Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
too much laser love
Edited by Smity42
Mangs. Just checking in from an Irish pub with free wi fi in Dubrovnik.
Cars of interest spotted in Europe so far:
one 180sx in Rome, but I think it may have been it's American cousin the 240sx.
And one four door 35 with infinity badges.
And lots of vw's
not when it comes to Fords ;)
Fords are awesome ;)
And lots of vw's
needs more beer :)
needs more beer :)
I am working on it. Beers here are $2 for pints.
Almost as good as hong kong, $5 for a four pack, sold at 7eleven and petrol stations
And lots of vw's
having fun bigfella?
Having fun, but as for hot beer wenches, can't quite give them the attention they deserve as my wife is with me at almost all times.
But as a general rule, Croatia seems to be filled with stunners.
Not like Serbia.....
lol - I knew something had been missing on this forum for a while. The good ol' serbia bashing :)
Dan_B:
I got this message from a dude on Boostcruising about a VG30DETT:
Hey mate i found out about the motor for you, it comes with everthing, turbo's ect. except no wiring harnes. It has dropped pressuse from one of the cyclinders but he dosen't know which one???? Apart from that he said it runs great. He said the price is $600 Neg.
What do you think?
Edited by Isola
Agree on the no. f**k the VG. Oh and as I said to John last night. f**k YOU GUYS. Burn Notice is awesome and I ended up going to bed at 2am last night because I couldnt stop watching them. Now I've got to stay in work and do my uni assignment because I know if I go home I'll never get anything done lol.
But Dan might know how to work some VG magic :blink:
Well, I question old mate's diagnostic technique.
He says:
now by 'dropped pressure' I would assume that means no compression? But how he tells it has no compression in 1 cylinder without testing them I don't know, and if he'd tested them he'd know which one it is. If its actually got no compression on 1 cylinder, forget it, its f**ked.
IF he actually means "not firing" on 1 cylinder then it could be something simple causing no fuel or spark to that cylinder, in which case it would probably be a very easy fix.
I would suggest, if you have any intention on buying it, do a compression test on it first and if the cylinders aren't all in spec and fairly even, then stay far FAR away, it's not worth the hassle.
If you can get the VG for like $400 I'd say go for it, if a cylinder is f**ked rebuild it yourself :D
The laser's now rolling on some sweet nolathane bushes in the front ;) oh yeahhhh
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
