At john:
Don't buy a VG with a dropped cylinder, they are a whore to rebuild, and as martin said, it could be low compression, if thats the case, expensive. Or it could be no compression, if thats the case, expensive paperweight.
If you want one, keep looking for a good running condition with loom.
Colin and Martin:
I feel your pain with burn notice, im there too.
As for the sucker with the GTR:
it will sell, then his "girlfriend" will leave him cause she sounds like a high maintenance "person" then he will be pissed off he sold it.
At john:
Colin and Martin:
Im up to Season 3 of burn notice and the disc/ my computer is throwing a hissy fit so I can't watch any more. Getting episodes 1-3 now hopefully the other disc works lol. Awesome show though
Completely agree on the GTR thing Dan so not worth selling it for a chick.
At john:
Colin and Martin:
1. My wallet thanks you
2. MWUAHAHAHAHAHAHAHAHAHAH!!!! :P
3. Should we e-mail him about his car and include my ad?
Get 16 as well, its not on the disc because it didn't fit
Alfa 4 burner would go good with a turbo...
if you want to make a tube frame of death then go for it.
Those 2 litres make stupid power with a turbo
I'm thinking two supermarket trolleys welded on top of each other, so if it flips on it's roof we can keep it rolling. Couple of other wheels here and there, some rubber dodgem car side strips, and if we have to... over night parts from ja-pan.
You can run atmo BOVs on stock ecu. Some skylines will go ok with them, others will have the stalling and popping or whatever.
I had my atmo SSQ and in the month or so I had it on, it stalled me twice. I was ok with that, and f**king loved the sound so would be keen to keep it if I wasn't worried about popo
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
