need to find a laundromat in paris. running out of shit to wear.....
I knew she was a broad minded person but c'mon, surely she ain't big enough in there to open a laundromat?
She's already got a bakery, fruit shop, antique dealer and dominos in there...
i think dark knight is a prety cool guy. eh fights star wars and dosent afraid of anything
Darth Vader would force choke the shit out of Batman, true story!
I missed something here didn't I
Anyone up for trivial pursuit tomorrow ? Kids version only. No cheating. You cant phone a friend either.
Hippos is out, the orange one called in sick. Apparently it's on a diet and balls aren't good for it.
I just checked the box.. and it's not a kids version... but it is on dvd however... so no pie... sorry.
damn you and your box *shakes fist*
hippos = out?
trivial pursuit = out?
I get the feeling Batman would be immune to the force. He just strikes me as that kinda guy :)
how exactly i one immune to the force? Sure he might not fall for mind tricks but if someone used the force to drop a f**king house on his head he is still in a spot of bother
yeah... but... it's fucking Batman!
and Jason, no one said hippos were out.
LINK FOR MISO!
that should help ya miso....
Cheers Dan,
had a look and none are really close to our joint.
decided i am going to rough it out till new york.
anyone got any reasonable shopping requests from new york or la? preferably new york, as i am only spending three days in la, and they are pretty booked out
on a sidenote, if anybody has any spare time, am in the hunt for a new vehicle
has to be a 2000 plus model
four doors
and automatic with under 100 xxx k's
price range is 10 - 15k.
at the moment a 07 current model lancer is winning the race, as at 14k it's a decent enough car and has another 2.5 years of warranty left
feel free to throw a spanner in the works
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
