10 minutes my ass...... the fronts took me 3 hours, they were seized on to the pins, and the bolts holding the pins on were also seized hahahahaha
So it's dinner, then gym, then see what I can do with this TRD laser
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>&">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
Also R34 N1 turbos with HKS actuators and dump pipes on boost for $1k in case anyone's interested (not mine but I do want them hahahaha)
CLICK FOR GLORY
Edited by mosquitocoils
Hahahaha I knew it from ages ago but only bothered digging it out again tonight hahaha
Those guys actually really know their shit
not much of a turn up (one new face though), and only grumpy and failbait were on.
Colin and I boycotted
wut?
How you know if there was a new face if you boycotted ? Or am i missing something ? :P
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
