I do not
Sure you do
For the record, bikini parade next weekend at Planet that a couple of the girls are in. Martin you are coming.
In. Hope its not during the day?
What about me ? :thumbsup:
What about you?
Oh you must have missed the part I put in invisible text. Hang on I'll see if I can quote it:
BAHAHAHAHAHAHAHA
You have posted more than the allowed number of quoted blocks of text
f**k You.
f**k You.
HA!
Bikini parade is at night at Planet, it'll probs be 10pm or 10:30pm start goes for like 15-30 mins. Not sure but I'd say it's Saturday night but I'll find out. Entry is like $10 to the club.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
