BOV sounds like success? Looking forward to epic flutters/skeeet! on Thursday
seems to be! I need to get it to the right level though, so in the presence of Mr Plod, I can shift gears around 4k and not have it scream.
which variety of circlip John? I've probably got the tool to do it
one of these
internal kinda ones
Yeah it's like $10 from supercrap for a pair of circlip pliers that comes with 4 different fittings or whatever... I got mine purely for my SSQ when it was on hahahaha
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :)
yeap, i've got the tool for that one
Hammer? I've always used long nosed pliers for them. Should probably get some circlip pliers though would be handy
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :blink:
Lol good idea.
Can do that if your long nose pliers are pointy enough. Can also get em with a couple of screwdrivers, but its a bit more effort
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :P
I asked you if they were HULK rated
fiber :down:
Tried a couple of allen keys with no glory... it's tighter than a jewish girl who was made to sign a prenup
any sharp implement is fine really
fiber :down:
Silly John he should of known not to get you mad :P
That's tight.
Morning mangs
Sup everyone... picked up a Gregorys service manual for the TRD off ebay last night for $20 :P
Drum brakes eat your fkn heart out.
Yes....... I = noob.
What's goin on today?
Doin' your mom
I need to get one of them for the alfa, but they are like $60 :down:.
Alfa factory manuals I have, but they are f*cking useless
Doin' yo mom, do-doin' yo mommm
Doin' your mom, yes yours, I saw her at the walmart, pickin out your drawers
Yeah they're expensive brand new. But sooo damn handy hey.
I NEVER look at my 31 one any more, but it sure was handy back in the day :down:. I refer to the XF one occasionally. The alfa one apparently has info on how to adjust camber etc, which I can't find in the factory manuals I have :P.
Plus most gregories/haynes have much better pics of things than these alfa factory manuals have.
Service manuals ftw.
Doin' your mom
I need to get one of them for the alfa, but they are like $60 :down: .
Buy one then scan it and sell it as an ebook on ebay/alfa forums. recoup your $60. Win.
I NEVER look at my 31 one any more, but it sure was handy back in the day :banana: . I refer to the XF one occasionally. The alfa one apparently has info on how to adjust camber etc, which I can't find in the factory manuals I have :) .
I should get one for the 32 tbh but I'll just end up winging it instead. I have the factory manuals but they aren't that helpful.
I concur.
I also has Autotune. Bitches.
Autotune your mum.
nissan factory manuals sh*t all over these alfa ones
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
