oh, and will seam weld from the a pillars to all the front suspension mount points. Theres just no practical way to get enough cage bars through there :3some:
Actually it looks like it may be possibly, by going inside the front guards (which are welded on :)). I might look at how to get those suckers off...
Whats there now?
Are you happy with the tune you got from STZ mang? They are a haltech premium rep or something... (gonna run a PS2000 on the alfa)
there is nothing there - its 100% bare.. hence why i asked
f**k moving all those cars - would have taken ages, would have been a fun night however lol
mate STZ were amazing, car runs so sexy - marty and mic said if there are any dramas just pop in and they'll have a look
defs recommend them bro!
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :3some:)
cant remember what turbo/power figure, but its definitely a very "tame" set up (not like high-octane racing for example)
give them a buzz fo-sho
I say dan buys it and sets up a workshop there :3some:
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :))
Cool as, they are about 2 minutes from my work :down:
...Will be a while till I need a tuner though ;), just doing my research...
Cool as, they are about 2 minutes from my work ;)
...Will be a while till I need a tuner though :) , just doing my research...
dude lets buy it - hoists win!
but yes STZ ftw! should go down and chat to them, i was there for ages just chilling - great guys
I say we all chip in and make it an Apocalypse fortress :3some:
Keen for apocalypse fortress/ somewhere with a hoist. but John needs a job first :)
Martin i can chase down the original workshop manuals for the GTV.
Phantom has relocated over near moss street from memory, i wanted to take the RX7........
If someone wants to front the cash i'll setup a workshop there and mini skid track.
Also, concrete carparks in the wet are too easy
I have them on that disc. They are sh*thouse :thumbsup:
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory :(. Looks like nothing adjustable on the rear :)
Build your own damn fort then.
Fine maybe I will...
Workshop+skid track = win.
Morning Mangs
Epic fog is epic :thumbsup:
Morning mang no fog here but it's pretty quiet on the way to work these days.
Morning to you fine gents
The fog's actually gotten worse since 6am...... go figure, usually it works the other way
Night all.
Is it just me or are those roll over ads at the top a pain in the rectal area? :):thumbsup:
I have them on that disc. They are sh*thouse :(
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory ;) . Looks like nothing adjustable on the rear :D
That's awesome. How much adjustability do you have though?
Could be that deadly fog that turns people inside out. I here it has been getting around again.
Night all.
So true. But they have to make money somehow.
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
