Was truly awesome. I went out briefly for an excuse to use my fog lights :thumbsup:
I don't have fog lights :). Sh*ts me off how many people were driving with NO lights though. FFS people, turn your lights on! Might not help you see, but helps you BE SEEN
That's awesome. How much adjustability do you have though?
Probably not much. Camber is adjustable via shims
Could be that deadly fog that turns people inside out. I here it has been getting around again.
Wut?
Cricket last night was awesome. Opened the batting and got 64 (4 overs), only went for a few runs in my two overs bowling, and took a caught and bowled landing on my dicky elbow.
Team still lost though :thumbsup: and I've been driving 1 handed as my elbow f*cking kills. Nice to find some form before the corporate games on the weekend though :)
I don't have fog lights :thumbsup:. Sh*ts me off how many people were driving with NO lights though. FFS people, turn your lights on! Might not help you see, but helps you BE SEEN
parkers are always a safe bet. but people are stupid and think it'll blind them...
Also, concrete carparks in the wet are too easy
i has wittnessed
Nakie
f**k man. now i have to stay at my desk for 5minutes to wait until it calms down :(
I don't have fog lights :( . Sh*ts me off how many people were driving with NO lights though. FFS people, turn your lights on! Might not help you see, but helps you BE SEEN
Wut?
Touche. Would be a bit of a prick adjusting it then eh.
Team still lost though :( and I've been driving 1 handed as my elbow f*cking kills. Nice to find some form before the corporate games on the weekend though :)
Good show old chap.
i has wittnessed
Hot.
Once it's shimmed up to 'epic-camber-stance-offset-win' there won't be any need to adjust it :(.
Good show old chap.
I say, jolly good. Cup of tea, old chap?
Once it's shimmed up to 'epic-camber-stance-offset-win' there won't be any need to adjust it :( .
Make your own shims out of 10mm steel plate.
Sounds delightful Martin. Scones too?
yeesssssssssssssssssssssssssss! skidzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
aaaaaaaaaaaaaahhhhhhhhhh
sup with you guys?
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
