Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
maybe the zinganator has run out of zing ?
Check that none of your dodgy macguyver hose connections are leaking
They all seem fine, car is boosting fine too, doesn't appear to be a leak. No one on Abottsford Road likes me very much after my test though :down:
Hahahaahahhahaha no one on Abbottsford rd likes me very much anyway :down:
I'll probs be over at basksins around 10 tonight? Too late?
Hahahaahahhahaha no one on Abbottsford rd likes me very much anyway ;)
The ice cream will be all melted then :down:
Bored. Finished playing with wiring diagrams.
@Ravi: We're generally gone by then bro, colon has transportation issues and I need sleep :down:
You can try your luck though, some people might hang around if there's a fair turnup
I think i just died from boredom.
Plus side work is finally going to put me through a Associate Degree in Civil Engineering
Yeah ravbat, probs a bit late. Colin has to "run ranga, run ranga, run, run, run" to make his train, which usually means I leave at the same time... being his lift and all :down:
Car is fixed. Was the hose going onto the BOV. I ditched the zip tie and went for some grip tape instead. Bit more air tight.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV ;)
Awesome. Good to hear it was nothing major. Hope we can sort Jason Phil's out as easily.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV :down:
lol
Isn't that like a 2 year full time course? :down:
Yep. Four years part time. Fun fun fun
I have full faith in you Tim / Steve.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
