@Jason:
Mang, I just realised something definitely isn't adding up with your car. If you are not going to get time to drop round this arvo, can you get pictures of the boost control set up in the engine bay (Near the left hand shock tower, you'll see 2 hoses, from memory 1 red/orange and 1 blue, try to get pic(s) showing where these hoses run to at both ends)
You changed them around on thursday remember. AVCR box has been disconected and i still have ( yay ) 1.5bar
how excited am i
alright i'll have a look wed/thurs, something's not adding up in my head.
I'm sure the vac line went to an external wastegate, but you have a stock turbo, and I don't think the setup was right for an external gate...
Edited by Smity42
Thanks for having a look
i'll take some pics tomorrow
you can't keep calling that tin of sardines a brabus.
the price of that smart car would barely pay for the wheel and tyre package of a real brabus.
Sarp mangs. Handed in my assignment with 7 minutes to spare. Awesome timing tbh. Whats the go with the GC tomorrow? We doing it or going to a different pug so Miso can watch the match?
Joshwa is going to ring up and find out what the G-O is
A Brabus Smart was like $65k..
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
